Can I get a replacement piece I broke off the small piece
Like in step 27 of replacing the joystick cable on the lite
@erica341 here is a website that you can lookup for technicians in your area. https://repairlegion.com/repair
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 98
4 件のコメント
A picture would help. Put one up so we can see the issue you have.
[deleted] さんによる
[image|2842293]
Sorry I’m new to this. Can you see the picture
Erica さんによる
@erica341 no sorry. If you click.edit on your original post there should be some icons appear. Click on the picture one then find your pic and upload it.
[deleted] さんによる
@erica341, are you saying you broke off the little black lever from the joystick cable connector that's mounted on the motherboard? Is that what you're referring to? "Piece" by itself doesn't tell us enough for us to be able to help.
Jerry Wheeler さんによる
