メインコンテンツにスキップ
1.6または1.8GHz デュアルコアプロセッサー、 2GBまたは4GBのSDRAM, 64GBまたは128GB SSD
192回答 すべてを表示
MacBook Air 11" refurb: Upper Case + Track Pad Q's
I'm going to try and do a sort of refurb on my old 11" macbook air 2011. One of my kids "cleaned it" with a spray air freshener and now the keyboard is shot. It's also had a bad track pad for a while now.
Question is, I'm going to try and replace both parts. What parts, beside the pad itself and the upper case, if any will I need? Also, what size/type screw drivers, will I need? I have a P5 and a T5 but I'm already into the process and can see I need something larger for disconnecting the display.
Any other tricky considerations?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi
If you are replacing the trackpad and top case you will need a top case with a keyboard backlight if the old one doesn't work(if it works you can just go around the edges to loosen it up and transfer it over) and you will need to transfer the old trackpad cable over to the new one
Heres the guides you will need for these repairs
Top case
MacBook Air 11" Mid 2011 Upper Case Replacement
Track pad
MacBook Air 11インチ Mid 2011 トラックパッドの交換
As for Screwdrivers and tools I recommend one of iFixits toolkits, they will last you a lifetime and have the majority of the bits you need for most repairs and I can say this from experience and in confidence
Heres on that should do the job for you:-)
Essential Electronics Toolkit
Hopefully this helps
Any questions please ask
Essential Electronics Toolkitの画像
製品
$29.95
MacBook Air 11" Mid 2011 トラックパッドの画像
ガイド
難易度:
中レベル
20 - 40 minutes
MacBook Air 11" Mid 2011 Upper Caseの画像
ガイド
難易度:
難しい
2 hours
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
trey meadows さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 39
