メインコンテンツにスキップ
Released in 2021, the TUF F15 features an Intel Core i& processor, NVIDIA GeForce RTX graphics, and a 15.6 inch anti-glare display.
15回答 すべてを表示
My Asus Tuf Dash F15 starting troubles
Hello
my asus tuf dash f15 sometimes run with black screen and a black power light and without keyboard light, they turn on sometimes when i connect it to another monitor via HDMI.
While working on the laptop sometimes, suddenly it turn off by hibernate not shutdown.
And sometimes it doesn't turn on again until I remove the charger.
And sometimes it doesn't work until I remove the battery and return it to board.
any suggestions?! and solutions??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi,
Check in Event Viewer for any Critical, Error or Warning events that may be logged at the same time as the problems occur.
If there are any (or a lot of the same sort) search online using the Event ID number and the Source info to find out what the cause of the event may be.
To get to Event Viewer, press the Win key + x key (both together) and click on the Event Viewer link.
Also check that the system files are OK by running an sfc /scannow command.
To do this type cmd in the search box on the desktop and when the Command app appears, click on Run as Administrator.
In the Command window type sfc /scannow and then press the Enter key.
Yes there is a space between the sfc and the / symbol.
This is old world computing as the mouse doesn't work in the Command window. If you make a typing error use the backspace key to step back and erase what has been typed in to where the error is and then start typing again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Firas Bourji さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 166
