メインコンテンツにスキップ
A microcontroller (also called an MCU for microcontroller unit) is a small computer placed on a single metal-oxide-semiconductor (MOS) integrated circuit (IC) chip.
4回答 すべてを表示
In need of a CM6400 any better places to find one?
Hi
I have been working on a blue yeti mic and have came to the conclusion that the CM6400 audio IC is the issue
https://www.cmedia.com.tw/products/USB20...
I have found many on AliExpress and I’m wondering if anyone can find any from anywhere else as AliExpress is saying it’s going to deliver mid march which is a bit long to wait
Any help is greatly appreciated
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
48 件のコメント
@hellomacos give this guys a holler https://www.4starelectronics.com/part_de... Lets see if they are quicker.
さんによる
@oldturkey03
Thanks for letting me know about them
Iv just sent a request
Let’s see what they come back with:-)
さんによる
@hellomacos just curious what issue do you have with the CM6400 ? I am also working on a Blue Yeti and already tried a whole bunch of firmware versions. I'm afraid I'm close to reaching the same conclusion as you..
さんによる
@io nut
My issue is that the recording is very very faint and there LOADS of static or buzz in the recording,I came to the conclusion that the chip was at fault as I couldn’t find any shorts in the board and the noise still appears when the capsules/mics are disconnected
The CM6400 chip also gets noticeably warmer on the board I’m working on
The CM6400 seems to controll a lot of that sort of stuff from what is says on its data sheet:-)
さんによる
@HelloMacOS
Hmm, well at least yours shows some signs if life..What hardware rev is printed on the boards? (one says yeti analog and the other says yeti digital, but the numbers should match). Also, do you know what firmware rev you have on it ?
さんによる
43件以上のコメントを表示
コメントを追加
2件の回答
選択されたソリューション
Hi @hellomacos
Maybe try contacting the manufacturer and ask if they have distributors in your location.
Never hurts to ask ;-)
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@jayeff
Thats a great idea!
il see if I can contact them
@oldturkey03 gave me someone to ask, if they don't come back with anything il ask the manufacturer
さんによる
コメントを追加
最も参考になった回答
have you searched digikey or mouser
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@tech_ni
I had a good look and can’t seem to find any that are the one I need
Only ones that share the same name but I’ve different purposes ;-{
I think it will have to be Aliexpress ,I’m going to keep looking about for a little more
Thanks for answering though:-)
さんによる
コメントを追加
回答を追加する
HelloMacOS さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 11
過去 30 日: 36
今までの合計 268
