メインコンテンツにスキップ
Repair guides and support for water softening systems.
4回答 すべてを表示
Shot in the dark for Hall Sensor for Culligan
I have a Culligan Gold series watersoftener. My unit can measure water flow. The way it does this is through a hall sensor that measures a small impeller that spins as the water flows. There is a magnet in the impeller that is read by the hall sensor.
I have tested the sensor by digging it out of it's epoxy bed and injecting 5 volts, it seem to be bad. I can't read any markings on the sensor. I don't know if it's a north or south sensing. (I don't know anything about hall sensors, only what I have learned in the last few days. I want to solder in a new sensor. It's about 4mm wide.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi,
What is the model number of the water softener device?
You may have to trawl though sites like this to hopefully find a suitable replacement.
If you see a suitable image of one in the list, click on it and you will find the datasheet where all the specs are shown for the component
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks Jayeff. I orders a small bundle of parts from there. At a dollar or two per sensor I can afford to mess around for a while. Watersofteners manufacturers still charge Ferrari prices for very simple parts.
さんによる
I just found a replacement at a culligan dealer. $180!! for a 2 dollar sensor on 12 inches of wire.
さんによる
@ alan
Did you see the part at all?
If so no doubt it was fully encased so you couldn't see the part number of the sensor.
Bit rich for just a sensor. Wonder how the price of it compares to the overall cost of the system?
Suppose it's like auto parts.
If you assembled a vehicle from parts it would be 3 times the cost of a new one ;-)
さんによる
コメントを追加
回答を追加する
alan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 126
