Want spin out water all the way
All cycles work except the spin cycles what is causing this?
You might try the troubleshooting tips hear if you're hearing an accommodating grinding noise: https://fixitnow.com/wp/2006/03/16/diagn...
My hope would be that it's a defective lid switch assembly. If you have a multimeter you can test that to be sure.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 18
Anglea Macemore spin cycle does not work at all? Does it drain properly? What is the exact model is your washer?
oldturkey03 さんによる
