メインコンテンツにスキップ
Processor 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz 2.42 GHz System type 64-bit operating system, x64-based processor
2回答 すべてを表示
Blank Screen, backlight works(brightness), external display works.
my model is asus vivobook 15, k513e, screen suddenly went blank while i was watching something, i can still change brightness of backlight, but display doesnt output anything, tried reset, hard reset, unplugging the batery, reseating the ram, checked the drivers, i tried updating the bios but cant bcs bios can only put out on main display so i cant even enter the bios, so far there is probably something wrong with a connection but i cant find any videos for this specific laptop or atleast rly similar, dont really know what else i can do, i added some pictures, opened a laptop, i reconnected the lcd cable so its either dead connector/cable or the connector on the monitor, still hope the screen isnt dead
Update (03/31/23)
Update, it was the screen, gave the laptop to the repairshop and they fixed it (and destroyed my battery connector male and female part on the mb so now the laptop is stationary) xdd
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
this could be a display issue or an issue with your display connector. Try something this vide to at least get into it. Once you get to the motherboard, take a couple of good pictures of it and post those with your QUESTION. That way we can see what you see. We will also need to know the exact model for your motherboard to see if schematics are available so we can try and check the display connector. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ive added the photos, recconnected the lcd cable on mb, couldnt do much more that that
さんによる
コメントを追加
回答を追加する
Tomaz Udovic さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 49
今までの合計 376
