メインコンテンツにスキップ
Repair guides and support information for televisions manufactured by RCA.
169回答 すべてを表示
TV screen is very dim after replacing new main board
So my aunts TV screen went out was the main board. So I replaced it and when I turn TV on your able too see the screen but it's very dim and when I adjust the brightness it doesn't seem to affect anything. I went thew some of these forms to diagnose the issue and found that possible the backlight board could be out what's the best way to troubleshoot this issue??
Its a RTU5540-B Rca
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@shingo87 yes, what you are describing sounds definitely like bad back lights. Two distinct possibilities. One being the backlight board, the other one being the backlight strips. Schematics for the boards are not available so it'll be hard to troubleshoot. I suggest you measure the voltage to the LED backlight strips. If the voltage is appropriate, it's your strips. If it is not, its most likely the board. Post some good pictures of all of your boards etc. with your question. That way we can see what you see. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sean J さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 24
