メインコンテンツにスキップ
Released July 2008, identified by model number QKL95M4. SN:33189362
4回答 すべてを表示
I have a Volume control problem.
I keep my volume to minimum but accidentally bumped the volume up button. I tried to reduce the volume but it only would increase. After trying several times, it’s now stuck on max volume. Will a factory reset correct the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It's possible that a factory reset could fix the issue with your volume control, but it's not guaranteed. Before attempting a factory reset, you could try a few other troubleshooting steps to see if they resolve the issue.
First, try restarting your device. Sometimes, simply turning it off and on again can reset any settings that may be causing problems.
If that doesn't work, try cleaning the volume buttons with a soft, dry cloth. It's possible that dirt or debris has gotten into the button and is causing it to stick or malfunction.
If neither of those steps works, you could try a factory reset. Keep in mind that this will erase all data and settings on your device, so be sure to back up any important information beforehand. To perform a factory reset, consult the user manual or contact the manufacturer for instructions specific to your device.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rick seitz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 12
今までの合計 99
