メインコンテンツにスキップ
The OnePlus 8T is an Android smartphone manufactured by OnePlus, released on 16 October 2020.
I have pink lines on the display after software update
After updating my OS to 12, I have noticed a couple of pink straight lines on my display. I have tried to restart and search for a solution but nothing worked. Now, Oneplus is saying they will repair only phones which are purchased 2 years back.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
https://howtofixgadgets.com/oneplus-upda...
This will help you brother,
ITS NOT YOUR FAULT ITS THE PROBLEM WITH ONEPLUS GO AND REPLACE YOUR SMARTPHONE.
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
Am glad that my query has helped you in getting a replacement. I have heard that the exclusive service center will take up the display replacement work whereas the authorised service center won't because they will have a delay in getting paid for the service from OnePlus it seems. I went to my nearest exclusive OnePlus service center and they have taken my phone without any complaints and have replaced my display the same day. The one thing they look for is if there are any dents or cracks on the phone. Hope this will help anyone who is facing the same issue.
さんによる
コメントを追加
最も参考になった回答
Hi
Usually when you see lines on a display that tends to mean that the display is internally damaged or physically cracked
If it’s only happened after a software update it could be worth fully wiping the phone and seeing if that resolves the issue
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have done the factory reset and checked but it did not work out.
さんによる
@suryakiran17124
I would recommend talking to the manufacturer of the device :-)
さんによる
コメントを追加
You may need to replace the display. iFixit has a screen for the 8T, but it's out of stock.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I need 8T display
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Surya Kiran Velamati さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 71
今までの合計 7,344
