メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2021年9月24日に発売されたiPhone 13 miniは、AppleのiPhone 13の小型版であり、miniシリーズのiPhoneとしては2世代目にあたります。5.4インチのOLED、A15 Bionicプロセッサ、デュアルリアカメラを搭載しています。
After Housing Swap Apple Pay Not Working
Hello
I did a Housing swap with a wireless charging pad installed and other small parts preinstalled. Now the customer's Apple pay is not working I think it might have to do with the wireless charging pad possibly part is serialized. Has anyone else come across this issue yet? Do you know what part is connected to apple pay?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
Define “not working”.
Is it just not sensing NFC, or there is an error when trying to activate a new card or paying with an existing card? Does Apple Pay in app or webpage work?
NFC is at the top end of the phone, check if you have messed up any of the top antennas and screw posts.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
I don't have the phone but those top antennas were replaced because small parts were pre-installed.
さんによる
@consistent Probably installed wrong.
さんによる
コメントを追加
The nfc sensor is in the charging coil so you might have to swap that over for it to work again. When you say ‘small parts’ what was included?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
NFC is NOT in the charging coil.
さんによる
コメントを追加
NFC antenna is on the top by rear camera.
When you say ApplePay doesn't work, it doesn't work at all or does Wallet show up when your double click side button? If it shows up, then it's antenna issue. make sure it's connected properly and replaced NFC antenna from original housing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If, by "not working" you mean that the customer gets the message "Unable to activate Face ID/Touch ID on this iPhone," then it is because the Face ID and Touch ID components are serialized to the logic board. They cannot be replaced. Apple cites security concerns for this, but I think it is just that Apple wants you to have one more reason to buy the latest iPhone instead of repairing your old one. #rightrorepair
Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark D Schlossman さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 27
今までの合計 1,434
