メインコンテンツにスキップ
廉価版で携帯バージョン、統合されたJoy-Conコントローラと若干縮小したスクリーンを持つNintendo Switchハードウェアです。2019年9月20日発売。
183回答 すべてを表示
Known good switch lite stopped working after testing repair parts
Hi there,
I have 2 switch lites that I purchased off ebay knowing they were broken, to refurbish. The first one I fixed no problem, just needed new sticks, so I decided to keep it as my personal switch. I was able to play on it for about a month, had zero issues with it.
Then the 2nd switch lite came along, when I opened it up, there's some minor water damage, indicators are red, a couple scorched pins here and there, so in an effort to see if there was anything seriously damaged on the motherboard, I swapped that one for the board in my switch.
I didn't have much luck, so I returned the motherboards to their homes, but now, my switch doesn't power on. It pulls 1.30 amps, the charge port is solid, all the connections are good but still no life out of it. I suspect the WD motherboard might have fried the LCD but is there anything I can look for or do to diagnose further and see if it's board level damage?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Not an expert but it makes me think that if you suspect a short from the old MB, I would check for continuity using a multimeter near the lcd, you might also want to check again if your ribbon cables are seated tightly also.
It could be as simple as the ribbon cables just not being tight or even a missing pin in any of those. That can happen easily with multiple reassemblies.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jermithy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 21
今までの合計 71
