メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
Why is my wifi and bluetooth not working
Why is my wifi and bluetooth not working Why is my wifi and bluetooth not working
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 109
30 件のコメント
Has the phone been dropped or damaged at all?
さんによる
I did factory reset but still not working
さんによる
I went in my hardware but my wifi and bluetooth are not listed in and its says unavoidable
What must I do
さんによる
I'm having the same issue on my Samsung Galaxy Note 20 Ultra. After the new update, they both stopped working.
さんによる
Check (verify) the time zone on your phone. I had this problem On the last update and resetting the TIMEZONE corrected the problem.
さんによる
25件以上のコメントを表示
コメントを追加
33件の回答
最も参考になった回答
There could be several reasons why your WiFi and Bluetooth are not working on your Samsung Galaxy A10s. Here are a few things you can try to troubleshoot the issue:
  1. Restart your phone: Sometimes, a simple restart can fix minor software issues.
  2. Check if the WiFi and Bluetooth toggle switches are on: Go to Settings > Connections and make sure that the toggle switches for WiFi and Bluetooth are turned on.
  3. Check if the WiFi and Bluetooth chips are enabled: Go to Settings > About phone > Hardware information and make sure that the WiFi and Bluetooth chips are listed as enabled.
  4. Check if there are any software updates available: Go to Settings > Software update and install any available updates.
  5. Check if there are any issues with the router: If you're trying to connect to WiFi and it's not working, try connecting to a different WiFi network to see if the issue is with the router.
  6. Reset the network settings: Go to Settings > General management > Reset > Reset network settings. This will reset all the WiFi and Bluetooth connections on your phone.
  7. Factory reset your phone: If none of the above solutions work, you may have to perform a factory reset of your phone. Keep in mind that this will erase all the data on your phone, so be sure to back up your important files before doing this. To factory reset your phone, go to Settings > General management > Reset > Factory data reset.
このアンサーは役に立ちましたか?
スコア 28
37 件のコメント:
I did factory reset but it still doesnt wrk
さんによる
Hi I did all but didn't work
さんによる
After the last Samsung update my wifi and Bluetooth isn't working as well
さんによる
Same for me, bluetooth and wifi can't be on. when I tried to open it it'll become off again.
さんによる
Same here to me
さんによる
32件以上のコメントを表示
コメントを追加
الخلل في ايسي بلوتوث والحل استبدال الايسي او تسخينه راح يرجع الجهاز طبيعي
Google translate:
The fault is in the bluetooth eSee, and the solution is to replace the eSee or heat it up, and the device will return to normal
このアンサーは役に立ちましたか?
スコア 10
11 件のコメント:
how to replace the esee or heat it up?
さんによる
Oh my gosh I did everything but still won't connect I'll just chill here and wait for the answer
さんによる
I am facing the same problem. My Wifi and Bluetooth is no longer working. Is there any Samsung Technician ca help me fix this problem? Thankyou.
さんによる
I am also facing this issues wifi and Bluetooth devices is not working plz tell me solve the solution plz
さんによる
Even if I refractory doesn't work
さんによる
6件以上のコメントを表示
コメントを追加
If your WiFi and bluetooth not working it is because of Ic problem you have to change it
このアンサーは役に立ちましたか?
スコア 8
2 件のコメント:
I did perform factory reset but still the same. Help me out pls
さんによる
How can we replace Or heat it where it is inside the phone?
さんによる
コメントを追加
If you have WhatsApp installed. Try cleaning WhatsApp data or uninstall WhatsApp. It works fine for me. A10S
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
It's a hardware issue. The phone's IC has a problem that's why the Bluetooth n WiFi don't work. The technician will demand approximately R250 to R350 to fix it.
さんによる
No hardware issue this is new update issue.
さんによる
Not an update issue. My phone has not received an update in years because it an old phone (Galaxy J5 prime). So it is a hardware issue-
さんによる
My Samsung a10s have the same problem
さんによる
コメントを追加
turn on bluetooth to connect to nearby devices
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Still my phone doesn't want to open
さんによる
コメントを追加
Reset your Wi-Fi router. The location of the reset button depends on what Wi-Fi router you are using but every Wi-Fi router has one.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you, Anthony, but this is not a solution to problem.
さんによる
コメントを追加
Why is my wife and Bluetooth working
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Try to format your phone
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Heat ic 300 ⁰c but how can i show the ic
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Well I will suggest to do the software update or system updated of your phone. Sometime outdated software version can also cause these kind of issue as well.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
You can't update phone without WiFi
さんによる
Even if I restart don't enable and not op6
さんによる
I did restart but still is not working
さんによる
コメントを追加
Its hardware issue my 2 devices one got resolved heating ic and second one had replaced ic MT6631N
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Wifi end blootot hospot
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
WiFi not opening
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Since the problem occurred with all users of this version of Samsung, this means that its function was stopped in the latest Samsung update.
さんによる
コメントを追加
My wife and bluetooth are not working on my phone my phone is Samsung A10s
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Bluetooth 11
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
WiFi and Bluetooth connection is not working
さんによる
コメントを追加
I have an S20+ and a WiFi 6 home network. I'm running the May 2023 update to OneUI 5.1.
Suddenly last night I was unable to connect to my home WiFi network. WiFi worked fine for all my other devices. I did lots of Google searches.... After trying all the obvious simple things (toggling Airplane Mode, Rebooting the phone, etc.), I looked in the S20+ Settings / Developer Options this morning and found "WiFi non-persistent MAC randomization" and turned it ON. WiFi almost instantly started working again on the phone.
I hope this helps others.
Cheers,
Scott.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My wifi and bloototh not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My wifi and Bluetooth malfunctioning since last 2 months
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Why my wife and bluetooth not working on network
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
さんによる
My bluetooth and wife are not working my phone is Samsung A10s
さんによる
Me 2 my Samsung A10s is not working
Bluetooth, WiFi and hotshot won't connect
さんによる
My wifi and bluetooth not working
さんによる
My Wifi and Bluetooth is not working in Samsung s20+ and developer option is also turned off
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My wifi & bluetooth not working, I have samsung Fold 3… .I got sick of samsung, Im going to buy Honor magic v3
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Wifi Bluetooth not working why problem factory already but not solve
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Why Bluetooth say disconnected
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Answer me plz
さんによる
コメントを追加
I do no but it's is in software complaint
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How i can fixit
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I don't no but I want to learn
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
f your Wi-Fi and Bluetooth aren't working, start by restarting your device and router, and check for simple issues like interference or drivers being outdated. If those don't work, try resetting your network settings, which will erase saved Wi-Fi passwords and Bluetooth pairings but can resolve connection problems. For persistent issues, consider updating your system or, as a last resort, performing a factory reset.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Replace or shake the wifi and Bluetooth IC
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Replace the ic
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Bluetooth isn't working my phone and isn't captured in songs
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
S20 not work Wi-Fi
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Yidnekachew さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 74
過去 30 日: 336
今までの合計 79,464
