Maytag Bravos XL washer stops mid-cycle, drains, shuts off
Same here, nothing happens!! Model #MVWB835DC2
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Here's the tech sheet for the washer.
Run the service diagnostic mode as per p.2 and check what error codes are shown
このアンサーは役に立ちましたか?
Ok, thank you for the tech manual. It did get me the error code F0E3. Out of balance. Which it normally tells me this on the screen with OFF. It is no longer letting me know on screen it will just fill wash for a few minutes stop and then drain. When it does this the light over the power button blinks and no other lights come on. When done draining all lights are out. It is only on for about 10 to 15 minutes total and everything inside is sopping wet. I have to turn it back on to spin out and actually drain the machine on the rinse and spin mode minus the extra rinse. The machine still does not completely spin out like normal but at this point does have the done light on.
Previously (years ago) I had tried to remove the wash plate due to stuff underneath and the rancid smell. I was unable to break loose the plate as it shows so simply on most videos it popping out. So I put everything back together and gave up. I fished out a quarter at this
I had to delete most of the rest of my comments due to it not allowing more than 1024 words. I was at 1890.
@ janette bush
You can add more to the comment once you pass 1024 characters by first submitting comment (up to 1024 characters) and then click on Edit in the comment (hover mouse in your comment and the option will appear) then add to the comment under what you previously had and then click Submit again
Cheers
Yes, I had already deleted what I said. Just frustrating I can’t get the problem fixed. Frustrating that I can not remove the wash plate to see what is under it or to be able to clean the tub. When I removed the back panel I noticed mold. Would love to get rid of the dead egg smell.
過去 24時間: 1
過去 7 日: 8
過去 30 日: 58
今までの合計 918
