メインコンテンツにスキップ
The second-generation (Mk 2) Ford Focus was launched in 2004 as a three- and five-door hatchback and an estate variant.
36回答 すべてを表示
Air only comes out of AC vents.
I get good heat and air conditioning from my front vents (AC vents), but when I select floor or defrost vents, the air still only blows from front vents. When I push the button for changing to defrost or any other position the light comes on but no change in air flow. What's the problem and how do I fix it? I did have it checked for faults at Auto-Zone but no faults came up
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Error codes may not exist for hvac problems. There may be a faulty actuator. One for temperature, another for directing airflow.
さんによる
コメントを追加
2件の回答
There Are doors that change position in the duct work that dictates where the air comes out when you change the selector it's possible that the selector circuit has came disconnected behind the panel or maybe the power circuit going to the selector has a short, broken line, or blown fuse. How ever it's a fair be that someone has had this problem. Try googling the exact car and exact problem. It could be a common issue and google will usually bring u a video of the repair procedure!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hi @retiredaf
Sounds like a problem with the blend door. Either a faulty blend door actuator or the door itself.
Here's some images from the 2008 Ford Focus service repair manual, that may help.
(click on image)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brad さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 22
過去 30 日: 71
今までの合計 232
