メインコンテンツにスキップ
Eighth generation of the Honda Civic.
59回答 すべてを表示
Why won’t my windows roll down?
After replacing the battery in a 2007 Honda civic, only the drivers window will roll down. When you press the down button from the drivers seat, I can hear clicking on the window that is supposed to roll down. However, when you press the down button from that seat, it doesn’t make any noise. The window lock is not on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Switches and relays that bring in the window motors carbon up over time. If it's easy to replace, get a new set of switches or have them cleaned out and tested. Secondly, the Body Control Module contains many relays that need replacing or cutting open and cleaning. They will also likely be dry-jointed and need a re-work. You can clean relay contacts by pinching a thin business card in them and pulling it through until you get no more black trace on the card.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Erica Blackler さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 28
今までの合計 168
