Whenever I charge my phone it displays error message,anyone help
unable to charge your device make sure that you are using a samsung compatible battery and charger and that your device is properly connected to the charger
Rajeev Shrestha, The first question is: Are you? (Using a Samsung compatible battery and charger.)
Try a different cable, different power brick and possibly a different power outlet.
If you’re still having problems, it could be that the battery is toast and you’ll have to replace it
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 32
