メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Pulse 4は、迫力のあるサウンドと魅惑的な360度のLEDライトショーを組み合わせたポータブルBluetoothスピーカーです。
Is my JBL Pulse 4 cannot be fixed?
Good Day Guys! My borrowed JBL PULSE 4 works fine, adding the use of JBL Portable app to customize lightings etc. But I had a problem after the software update of the JBL Pulse 4 using the app, after the update was completed, the speaker won't turn on anymore, neither is charging, it doesn't respond to anything, completely nothing works. The app JBL Portable, broke my borrowed speaker because of the software update it showed on the app. Please help, is there any ways? 😭😭😭
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Have you tried a hard reset? I know you said it won't turn on, go through the process and see what happens.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What's the hard reset you're talking about? I've tried long pressing the power button for 30 secs or more, doesn't work. Tried pressing both play button and volume up button, nothing happened. And any other combinations, I guess. What else?
さんによる
Have you tried both power and volume up together for 30 seconds? Then try and turn it on? My bose wouldn't turn on so I plugged the charger in then when it made a sound I turned it on and unplugged the charger. Been fine ever since. I take it was charging OK before the issue?
さんによる
コメントを追加
回答を追加する
April Chan R. Sabio さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 18
今までの合計 853
