メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
iPhone 4 drains battery caused by speakers
My iPhone 4's speaker blew out and since that day it makes strange sounds even when it is closed (like a continuous buzzing sound) and doesn't end until it drains the battery totally. I am going to order a replacement speaker for around 15$ but I have to go abroad in 2 days so won't have time to wait for the package. I know that the speaker unit is completely different from the mic/USB slot and can be replaced easily.
My question is will my iPhone 4 work without an internal speaker plugged in? (nothing to cover that spot inside)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Hi Josh,
Unfortunately a majority of WiFi/Overall Phone Reception is relayed through that part. This part is called the "Antenna Bridge" or "Speaker Assembly" (both the same thing).
As you can see, there are 4 metal feet that connected to the iPhone frame. The feet then use the entire frame of the iPhone as an "extended antenna", and if broken off greatly reduce iPhone reception.
These feet are connected to the antenna cable which MUST be connected to the logic board or you will not receive and WiFi/Phone Reception at all.
So in short, if you do not have this part installed, you will not be able to make phone calls or connect to WiFi, disabling the "Phone" and "Internet" aspects of the iPhone. If you can survive without these functions then you can just use your iPhone as a music/gaming device, however it is not recommended to leave parts missing inside an iPhone on purpose, as it can possibly cause other parts to fall out of place and become damaged.
As a short term fix, you could possibly get some type of material (plastic or rubber) and cut them into the size that covers the two feet that connect the speaker to the logic board and place it between the feet to stop the connection from being made. Alternatively you could just break the feet off and render the entire part useless, however seeing as the part is damaged already and is in need for replacement it is also another viable option.
Hope this helps! :)
Martin
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Joshua Kyrits さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 384
