メインコンテンツにスキップ
Repair guides and support for your Toshiba TV.
193回答 すべてを表示
Volume was all the way up,pressed volume down,loud pop,hasnt worked
Model number 55SL412U
12V. 60Hz. 1.2 Amps max
TV volume was all the way up at 99, then my mother pressed the volume down button and it made a loud pop, hasnt worked since. The stand by light does come on. But nothing else. Screen is completely black. No sound or anything at all.
Update (01/02/2023)
Picture of back of tv where something seems to have blown, toshiba tv, 55 inch I think, several years old, thanks to anyone who can help!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @megan8
Disconnect the power from the TV and then remove the back cover from the TV and check the power board and the mainboard for any obviously damaged components i.e. blown or burnt looking.
If you do spot something, post an image of the component back here for further help.
Here's how to iFixitでの質問に画像を追加する方法 on ifixit.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi ,
Looks like the power mosfets Q101 and Q102 are blown.
You may be able to replace them IF you can still read the markings on them if they haven't been burnt off. Otherwise you may just have to replace the power board as Toshiba isn't known for releasing schematic diagrams of their boards so that you can identify them that way.
You need to get the correct board however so look for the board number (printed on the board itself), and then search online using that information.
Not sure but it "might"be something like PK101V24401 or similar.
さんによる
コメントを追加
回答を追加する
Megan Anderson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 26
