メインコンテンツにスキップ
2019年11月4日に発売されたXbox One Elite Wireless Series 2コントローラーは、Xbox One、X、&Sコンソールのほか、Windows 10/11を搭載したPCに対応します。
40回答 すべてを表示
What are the batteries underneath the battery for?
I'm talking about the two silver circular batteries that sit underneath the actual rechargeable battery. I included a photo.
I'm dealing with a controller that suffered water damage but would power on when it was plugged in. I wanted to open it up and see if I could just clean it out to get the battery charging but if not planned to replace the battery. Cleaned it up, put it back together and now it wouldn't turn on even when plugged in. Now that I replaced the battery and the battery contacts, it still does not power on. I did notice discoloration (burn marks?) on one of the circular batteries underneath. Short of the actual board being bad this is the only thing I could think of but I'm not sure exactly what their function are and if could cause this issue.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
those be broken motion sensers and ur missing a 3 pin rivit piece 2
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Can you show me a pic of what that’ll look like?
さんによる
コメントを追加
Those two marked components are magnets. They are used to mount and properly orient the controller to the charging dock. If you want or need to remove them, take a marker and draw a mark on each of the indicating up. They are polarized. If a marker is not used before they are removed, you can still figure out how they are oriented by loosely placing on the controller as it is sitting on the charging dock. They will flip and turn to orient themselves to the magnets located inside the docking port.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
RobertAdams313 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 22
今までの合計 185
