メインコンテンツにスキップ
Oculus Quest 2は、2019年5月21日に発売されたOculus Questの後継モデルです。Quest 2は、プロセッサーの改良とタッチコントローラーの再デザインが施されています。
172回答 すべてを表示
My X button wont work any more after using too much contact cleaner
This happened a couple weeks back when I noticed my joystick had drift, naturally I grabbed my WD-40 Contact cleaner, took the battery out and sprayed a lot on there, then I used my air duster to dry it called it a day, put the battery back in and loaded up blade and sorcery but I noticed my x button didn't work however the capacitive touch center still worked for it. I replaced the battery and let it dry for a bit but still it wont work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
WD-40 is just mineral oil. The oil probably is lubricating the membrane and switch so much that it cannot read a press. To fix this I would recommend using 90% or higher isopropyl alcohol to clean away the oils. Be sure to not use WD-40 on electronics, as it is meant to lubricate and protect metal parts.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The original poster said they used WD-40 Contact Cleaner, which is specifically used for electrical components.
さんによる
コメントを追加
Same. I have used WD-40 specialist contact cleaner for all my oculus controllers whenever I have a drift problem. For some of my games I use the cleaner spray every single day. WORKS WONDERS. I have however had two single controllers break directly after using the spray. One, the joystick just popped right out of a side and was disconnected from the controller! And the other incident was the A button stopped working, for good. Like you I have been unable to repair it.
*The other commenter thinks you are using actual WD-40 and not the one fore electrical parts.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
oisin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 47
今までの合計 803
