メインコンテンツにスキップ
2018年7月に発売された、モデル番号{A1989 / EMC3214}のMacBook Pro13インチモデルにはクアッドコアi5と i7 を搭載しており、グラフィックにIntel Iris Plusが統合されています。
200回答 すべてを表示
Logic board replacement. Is it possible due to T2 chip?
Hello,
I'm looking to move a logic board from one mac to another due to one having a swollen battery and the other being a much better spec. Will the Mac be useable without AST 2 System config?
I'm aware about bringing the Touch ID over with it but it will have a new top case and possible display.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi
As far as I know aslong as you have the same shape Board that is from the same year your top case should work
Your screen could work but I cannot confirm that it will work fully as apple does like to remove features or brick the device when people replace things
If the board is a different shape it won’t work as the different models have different heatsinks and different numbers of ports
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks for the info! The board is the same size so should be fine. I'm more wondering if diagnostics or configs from AST2 need to be run on logic board migration as the logic board will be connected to a different (but exact same) display, trackpad, keyboard and battery.
Any ideas? Thanks!
さんによる
@slat
Hmmm not too sure about that one
The AST2 might be needed if you want True Tone and Touch ID paired but it might be worth going ahead and seeing what happens
さんによる
コメントを追加
回答を追加する
Jack さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 14
今までの合計 186
