メインコンテンツにスキップ
8.0 Megapixels, 3.6x optical zoom, 2.6" LCD Monitor
Canon Powershot S80 White vertical lines on screen and photo
White vertical lines on screen and photo won't go away.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
I'm not an expert on digital cameras by any means, but I do understand the technology behind them, so here are my thoughts on this problem.
First off, the lines you're seeing obviously aren't an artifact of a damaged screen. On other devices like cell phones with display issues you'll see the problem on the screen but if you take a screenshot it won't show the problem. Here, you're seeing the lines on the saved photos as well as on the display which means the lines are there before it gets saved or displayed.
The only other source for image problems like that is the CCD array that captures the image. I have no idea how to replace that part by itself, but a quick search came up with a complete lens assembly that appears to include the CCD array on AliExpress.
Lens Zoom Unit For Canon PowerShot S80 Digital Camera Repair Part Silver + CCD
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The CCD could be replaced if it would available. It is the part that is mounted to the back of the lens mechansim and attaches with the flex as shown in step 12 on here https://www.ifixit.com/Guide/Canon+Power... step
Cost is probably more than the complete assembly you've linked to ;-)
さんによる
コメントを追加
The vertical white lines.
Lens shutter diaphragm is not closing after the shutter timing.
  1. Shutter blades are sticky.
  2. Solenoid of shutter is non working.
  3. Flex is damaged.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dimensionized さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 248
