メインコンテンツにスキップ
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
54回答 すべてを表示
HR-S7000u replacement head and service manual.
Doe anyone know where I can find a replacement heads or upper video drum for HR-S7000U seems like parts are hard to come by and parts units are over $200 for a possible good part!
Update (12/17/2022)
Ii did the same thing been looking for weeks for the manual found the HR-S7000EU it was a different beast all together here a shot of the drum
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @stereo068
Here are the drum sub assembly and the upper drum assembly (supplier example only) for the recorder.
The part numbers are JVC LP20617-008A and LP20030-015A respectively.
Here's the service manual for the recorder. The chassis and mechanical parts list is on p.26-27.
Search online using the part number only to maybe find other suppliers. i didn't look too hard ;-) As you said there's not much out there but maybe you can find either a used S7800U/U(C), HR-S2110T or S6700KR recorder at a reasonable price and use that as a parts donor.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
Thank you Jay ! The manual is for S7800 it's completely different than the S7000U I'm working on the Upper Drum is also different the original part has JVCH73V0 and PDM3017 and is 4 heads most places show it as 2 heads .
さんによる
@stereo068
OK
I was only going by the title on the manual where it says S87000U/U(C) as shown in the link I posted.
This is what shows for a PDM3017 which doesn't sound like a drum part
さんによる
Ii did the same thing been looking for weeks for the manual found the HR-S7000EU it was a different beast all together here a shot of the drum[image|2818865
さんによる
@stereo068
Do you think that this may be an option to consider?
Depending on shipping of course. Bit of a gamble I know
さんによる
That's a S7100U completely different the HR-S7000U is a front loading SVHS machine and the parts machines are over $200 at that point its more than it's worth as I was hoping it will work with a simple height adjustment without the test tape and scope!
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Marlin K さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 9
今までの合計 143
