Flat ribbon cable is broken
Is there a possibility to get the ribbon cable between lower circuit board and top circuit board as a spare part?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I found this. Search for "30-Pin FFC/FPC Flexible Flat Ribbon Cable Pitch 0.5-1mm 6/10/15/20/25/30/40cm" on eBay.
I ordered the 0.5mm pitch, 25cm long. I get 5 for $1.40. I haven't got it yet. Let me guess, you dropped yours and split the cable?
このアンサーは役に立ちましたか?
I noticed your original post was for the Revolve (Non-Plus) . Mine was for the Revolve Plus. You can probably find what you need on eBay.
Unfortunately, I have not found one yet. Apparently there are not as a spare part.
Hans, did you read the part number off the cable. This place on eBay will make custom ribbon cables. Just figure out how many pins it is and what length you need. It is probably 0.5 pitch.
過去 24時間: 2
過去 7 日: 5
過去 30 日: 31
今までの合計 371
1件のコメント
Did you find one as I'm after one too
Stu Taylor さんによる
