メインコンテンツにスキップ
Repair and disassembly instructions for Jura Impressa F50 fully automatic coffee machines
9回答 すべてを表示
The water flow is just a trickle
Hi, my water flow from the faucet is so slow and practically dripping taking a long time to fill a cup, I have taken it all apart and hoovered the guts, no sign of leaking, I have taken the faucet off and cleaned the tubes cos I read they can sometimes get clogged with coffee granules...it has been asking to open tap a lot and fill water when the water tank is completely full....I am at a loss
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Maybe there is an issue with a pressure valve. That would cause the lack of water pressure
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
@sazzy79 try to clean it like suggested on here You also want to try to descale it. For that you can likely use this video There are plenty of descaling agents out there so don't get hang up on the brand, etc. @vauweh is the coffeemaker Guru on here and hopefully he can provide you with a more in depth answer
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
S reid さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 25
今までの合計 462
