Why do my back up lights come on when I press the brakes?
Why do my back lights come on when I press the brakes on my 97 Honda Civic?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Do the brake lights come on when you select reverse gear without applying the brake pedal?
Try this with the engine off.
If so check for a short circuit between the green/black wire going to the reversing lights and the green/white wire going to the brake lights in either taillight assembly.
The wires may be pinched together somewhere in the harness
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 239
3 件のコメント
When I apply the brakes, the brake lights and the back up lights come on together
Mr. Dre さんによる
Even when I'm driving, back up lights come on when I apply the brakes and I can't figure out why...
Mr. Dre さんによる
@Mr. Dre
See answer below
jayeff さんによる
