メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Levono Thinkbook 13s-IWL was released May 2019, and is identified by the model number 20R9. Below you can find key details, features, and repair instructions for this device.
Which battery does this laptop use
I'd like to replace the battery of this laptop, because Lenovo Vantage said it had some problems, but it's out of warranty. Now, when I look at the page of this laptop, I only see a camera. Does this laptop use a battery specifically for this laptop, or does it use a battery that's also used by other laptops?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @gestoordeend
According to the parts list for the laptop, there a 6 battery models that are compatible with the laptop, (click on Select Commodity > Rechargeable Batteries, internal (6).
Here's the hardware maintenance manual for the laptop.
Go to p.31 to view the procedure to remove the battery. The model part number is printed on the battery itself, if you wish to verify that you're getting the same as is installed now.
Search online using the part number only to find suppliers that suit you best.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jon van Maaren さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 17
今までの合計 632
