メインコンテンツにスキップ
2012年11月2日に発売された第四世代のiPadです。16、32、64GBモデルがあります。モデル番号はA1458です。
218回答 すべてを表示
My top ribbon doesnt work
When I was changing the battery I had to unplug the top ribbon that holds the aux, cameras and power button and now ive plugged it back in the whole top ribbon doesnt work what could I have done or fix it?
To add to that now it doesnt turn on at all after Ive closed it to make sure its properly plugged in
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
TheBlooner AceTin, Unfortunately, even though it might be a pain, you’ll have to open it back up again! Once opened, unplug the battery and then the other connections you had off before. Inspect the flex cables and connectors closely (a magnifying glass at least, if you don’t have a microscope) and then clean both sides (board and cable) side of the connectors with >99% isopropyl alcohol. Normal rubbing alcohol and the likes will not do, as they mostly contain to many additives to the alcohol.
Once you’ve inspected and cleaned everything very thoroughly, connect everything back (battery last) and check functionality before closing it up again! That last part is learned through experience (I had to open the first few devices I did back up again, because I hadn’t checked and verified functionality).
If it still a problem even though everything looks OK, let us know and we’ll have to dig a bit further.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Is there something else I could use if I dont have isopropyl alcohol?
さんによる
TheBlooner AceTin, Unfortunately there’s not much. The only thing is to get some form of HIGH percentage alcohol. Most rubbing alcohol is 70% at best, which isn’t enough. It needs to be at least 90%, and as few additives as possible
さんによる
@TheBlooner AceTin Forget the alcohol. I’ve repaired iPads and tablets, mobile phones for years and not used alcohol on connectors once. Remove and reseat the top cable making sure it’s inserted correctly and all the way in then try it with the device still open. If it still doesn’t work check the cable and connector for damage.
さんによる
コメントを追加
回答を追加する
TheBlooner AceTin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 35
