メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad mini 5-モデルA2133のWi-Fi版のガイドです。2019年3月発売のiPad mini 5は、iPad mini 4の後継モデルです。
iPad turns on and off constantly with the new battery
iPad turns on and off constantly with the new battery. It does not turn on at all when not plugged in. When it is plugged in, the Apple logo appears for a few seconds then disappears, again and again. The iPad works fine when I plug the old battery back in.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Max,
There may be a lot of reasons for it, but chances are good your new battery is defective. The battery is not just a battery, but also includes electronics that communicate with the iPad and report things like current charge level and temperature. If that circuitry isn't working it can have all kinds of effects on the system such as the inability to charge the battery and possible software issues if its sensors can't be read.
If you bought the battery here on iFixit, contact them at support@ifixit.com and they'll get you fixed up with a replacement; they have a 1 year warranty on batteries and are very good at honoring that warranty. If you bought it somewhere else, you'll need to contact your supplier about a return/exchange/refund. Despite the best efforts of any supplier, it's always possible for a bad battery to slip through whatever quality checks they do, so getting a bad one is far from unheard of.
The fact that it works fine with the old battery is positive proof that the new battery is defective.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Max Collin さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 10
今までの合計 189
