メインコンテンツにスキップ
What would be causing me to only see an unilluminated image on my d
Hi I have an ux533fd. I purchased it with left hinge seperation from screen. screen worked upon recipt. Recently I cant see desktop image in display unless i shine a light on the screen, then its all there, also is there on 2nd display. Machine has been factory reset as well. So my question is, what would cause your display not to be backlit but still show hi res image?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
A Bee failed backlight strips would be might first suspect. Since you were dealing with a bad hinge, it is possible that this is a wiring issue. Of course, you cannot rule out problems with the backlight driver or even a blown backlight fuse. WE would need to know the exact motherboard number for your laptop so that we could try to get you more information about the fuse, the connector etc. ******
Update (12/07/2022)
@A Bee it's one of those depends. We'll have to see what you got going on there. It is possible that it does or it may be part of the rest of the wiring. It should become obvious/visible if you remove the bottom cover of your laptop and we can see what all of that looks like. You can always post images with your QUESTION (Questions and Answers only, not comments) so we can see what you see. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
ill find the board number and post. i didnt know the backlight had a driver. does the backlight have seperate wiring from the lcd?
さんによる
コメントを追加
回答を追加する
A Bee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 40
