メインコンテンツにスキップ
Appleの主要モデルである2021年のiPhoneは、9月24日に発売され、6.1インチの有機ELディスプレイ、デュアル12MPカメラシステムを搭載し、5色のカラーバリエーションが用意されています。iPhone 12の後継モデルです。
41回答 すべてを表示
iPhone 13 front camera replacement walkthrough
I have an iPhone 13 with a damaged front camera. I haven't been able to find anyone that has done this replacement and I haven't worked on any 13's yet.
It looks like it's a fairly straight forward swap with the caveat that face ID won't work without some soldering being done. TBH I'm fine without having face ID.
Can anyone confirm that it's a simple part swap?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
might be of some help if its the correct camera. https://www.youtube.com/watch?v=BSH1cy1F...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Perfect. That's a Pro, but I'm sure it's similar for the 13.
さんによる
コメントを追加
Hi Bill,
I did find a guide on a Spanish site; it's got an option for the English language, but it didn't seem to work well until I allowed Chrome to autotranslate, and after that it seemed to be usable.
Manuals / Apple iPhone 13 / Front cameras
I can't be sure about the iPhone 13, but on the 11 Pro at least, you can replace just the camera without losing Face ID. It involves taking a Dremel to the metal housing and digging out the camera, leaving the dot projector and IR camera in place. You can get the general idea from viewing the iPhone 11 Pro guide that I helped out on.
iPhone 11 Pro Front Camera Replacement Without Losing Face ID - iFixit Repair Guide
I was looking at the same situation on an iPhone X and was able to find a site that sold just the camera alone without the rest of the front camera assembly, along with a replacement metal bracket that could be used if you decide to just destroy the old one in the process of disassembling it. Turned out to be the IR camera that was causing the problems so I didn't end up doing the repair, but same logic applies; use your specific guide to get the camera out, then use the same technique to remove the camera from the assembly.
Good luck; let us know how it goes! Take pictures; it would be great if you authored a new guide to that replacement for all the other people who are going to run into the same problem. It's actually pretty easy to do, and there's plenty of people, myself included, who will be happy to help you with it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bill Shannon さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 22
過去 30 日: 123
今までの合計 348
