Why is my mobile not charging?
I replaced the battery once and after some days it isn’t changing
If your Samsung Galaxy A5 is not charging after you replaced the battery, there may be a problem with the battery, the charging port, or another component of the phone. Here are some possible causes and solutions for this issue:
Overall, if your Galaxy A5 is not charging after you replaced the battery, there may be a problem with the battery, charging port, or charging cable or adapter. Try the solutions above to troubleshoot the issue and get your phone charging properly again.
このアンサーは役に立ちましたか?
Mayur Hotkar use an USB Ammeter and connect it between your charger and your phone. See how many amps are being "pulled" when trying to charge it. It'll give you a quick indication if it is your battery or the charging port.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 138
