メインコンテンツにスキップ
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
79回答 すべてを表示
Why is my JBL E45BT wireless headphone sound quality very poor?
It's been 4 years since I bought the JBL E45BT wireless headphones. Now it has poor sound quality, doesn't connect to any device easily & also the cable which connects the headphone-laptop doesn't work either. Is it not usebale anymore? Please help. Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @a51
Poor sound quality may be due to a failing battery. Even rechargeable batteries have a lifespan.
Try changing the battery and check if the sound is better.
Here's a video that may help. I realize that it is not about changing the battery but it shows how to open the headphones and then the battery can be accessed (see battery at 1:19 minutes into the video) and disconnected from the circuit board and replaced.
Search online for CS-JBE300SL battery to find suppliers that suit you best.
As to why the 3.5mm stereo audio cable connection to the laptop doesn't work it may be a faulty jack in the headphones or the jack may have come loose from the board. Have you tried using a different compatible cable just in case it is the cable that's faulty?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
A. Prasanth De Zoysa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 104
