Why does my a/c shoot out threw all air vents?
My 2010 Honda accord lx a/c will only shoot air to the feet even though if it’s on front windshield or if I have click too shoot air at my face it only shoot threw out the feet area
gonzalezcarlos.99 could be a failed blend door actuator or AIR MIX CONTROL MOTOR. Check on something like this video to work on it. Here is the complete HVAC module from the service manual. Page 9 shows you how to run the self-diagnostics for your HVAC control unit. See if that gives you something else. 2010 Honda Accord HVAC
このアンサーは役に立ちましたか?
Since You indicate that you have an LX model, I would assume that you don't have a climate control system (meaning split controls for driver and front passenger area temperature control.)
That said, you can run a check on your system from the controls:
NOTE:
I suspect thaat the DTC will show 10 or 11 blinks, since you have a '10 Accord LX (assuming automatic transmission) and per the service manual:
I don't have a simple way to display the pages in the Honda Service Manual for your car, but if you want to comment as to results if you run the diagnostic, I can maybe add to the answer.
このアンサーは役に立ちましたか?
My 2010 accord is blinking 10x what should my next step be?
Mode doors can be controlled manually by dial/knob, cable and linkages or operated by servo motor. You'll have to look around the hvac box from driver's and passenger side to determine configuration. Removing the hvac control panel may help too.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 26
今までの合計 434
