Assuming the phone was not damaged (e.g. after a fall/liquid spill), here are some guidelines provided by Google to troubleshoot the problem: https://support.google.com/android/answe...
Feel free to let us know if you solved the issue or if you're still having problems after going through the steps
Simone さんによる
Hi @nathanyacub,
Does the phone indicate that the battery is charging when the charger is connected?
Have you tried using a different known working compatible charger or connecting the phone to a computer's USB port to see if it charges at least?
If it can't charge the battery then the battery will become depleted and the phone won't turn on either way, with the charger or the battery.
jayeff さんによる
