Why does my washer drum keep rising as it takes forever to drain?
I noticed this lately. It seems to drain forever, and the drum keeps rising. Is there a clog or something somewhere?
Here's the tech sheet for your washer model (if it is the WTW4816FW2 that you asked about before).
Run the diagnostics as described in the guide and check what error code, if any, show up.
On p.11 it shows the possible causes for a "won't drain" problem that may also help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 30
