New oven has 4 wires but house has only 3
The house supply has 3 wires Red , Black & Green ,
The oven has 3 terminals labeled 1 ,2 & N plus the ground ring connection green .
The oven is a Chef premier model # Euc5350w , i am residing in australia if that helps
Would i just run a bootstrap between the ground and neutral ?
I only have a cheap small meter , i just tried it upon the red & black supply wires which maxed the meters needle so the red and black are opposite polarity ? It did the same also between the green and red, between the green and black there is continuity
.[ UPDATE]So i got brave and wired it up , linking neutral terminal to the ground/green , black to terminal 1 red to terminal 2 and the hotplates work but oven doesnt , switched the positions of red and black and oven works but hotplates dont .. can anyone please help ?
