Battery parts number for 39.3whr and 52.5whr
what is the battery part number for this laptop? The 39.3Whr and 52.5Whr?
Hi,
Here are the Lenovo part numbers for all of the batteries that are compatible with the laptop
T14 Gen 3 Type 21AH & Type 21AJ
52.5Wh 4 cell battery - part numbers
5B10W51866, 5B10W51865, 5B10W51867, 5B10W51863
39.3Wh 3 cell battery - part numbers
5B10W51862, 5B10W51860, 5B10W51864, 5B10W51861
Here's the hardware maintenance manual for the laptop.
Go to p.61 & p.66 to view the procedure to safely remove the battery from the laptop.
このアンサーは役に立ちましたか?
The answer by @jayeff does not point to parts on iFixit that are compatible for a T14 Gen 3 battery. When I searched for the part numbers above, I got to this part, which is not compatible.
I'll be returning this.
このアンサーは役に立ちましたか?
Hi @stevenesbitt,
Just so you know that they are "Lenovo part numbers" for the battery and not the actual battery model number as used by the battery manufacturer. Lenovo doesn't make batteries but has them made to order by battery manufacturers
Part numbers and model numbers can be different, yet the battery is compatible
過去 24時間: 0
過去 7 日: 7
過去 30 日: 36
今までの合計 903
