Replacing hard drive with ssd drive
Can someone give me instruction on how to replace hard drive with ssd drive?
https://youtu.be/watch?v=EKzqMIC8nUI - to remove top cover and
https://youtu.be/watch?v=M-ynZ5m1bR4 to remove drive. The optical disc bay is removed by taking out the small screw on the bottom ( the one he didn't instruct to remove. )
You may have already fixed this, but this is the top result on Google and others may use it.
このアンサーは役に立ちましたか?
As long as you have the right ssd drive, its a simple swap. Remove the old hard drive, replace the new ssd. It was 2 cables for SSD on my PC but for some Laptops its just 1 connector
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 489
