メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
iPhone 4 battery problem
I just got a refurbished iPhone 4 from AT&T, and right off the bat, when I plugged it in and tried to charge it, and it took abnormally long to charge, but I didn't think anything of it because it is a new, out of the box, phone and thought maybe it needed a good charge. As soon as it had enough battery to hold a charge I unplugged it and used it, and didn't let it fully charge. Every so often it would just turn off and then I would try to turn it back on and it would show the completely dead battery, with a little charging symbol below it, so naturally I plugged it in and then it would reboot and show that it had above half battery. This happens every once in awhile when I am taking calls and playing Templerun when my phone is at about 64% battery. Should I just ask Apple for another phone or just fix it myself? I fix iPhones, but just never came across this problem. Anything helps, thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
If you just got it, it probably has at least a 30-60 day warranty. I wouldn't waste my time or money, get another one quickly.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Douglas James さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 860
