メインコンテンツにスキップ
Repair guides for the 2018 version of the Samsung Galaxy A8 Android smartphone released in January 2018. Good features at a good price. Model Number SM-A530F
20回答 すべてを表示
Phone drowned mb replaced didn’t help
Hi guys
My gf phone couple years ago ended up in water. Few months ago I turned it on and it worked for couple of weeks. Then water 💦 warning came on.
Since then trying to fixes it I have replaced the motherboard and later battery as well but it did not help.
Any ideas what is the problem now and how to fixed it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
kollesco since you already switched the main board and the battery, I would check in the back casing with the antennas etc. Your charging port which is commonly the source of this is part of the main board so it should not be the issue. Some people say if they sign out of their Samsung accounts, clear the phones cache and get into safe mode, that this message stopped from appearing. Just make sure you have all of your files/password etc. before attempting this.
How to Disable Moisture Detected Error
If the moisture detected error won’t go away even after cleaning and wiping the USB port, and you are still unable to charge your Samsung device, try the following things.
  1. Use a Wireless charger: Get a wireless charger so that your Samsung device does not run out of battery until the moisture has been detected issue persists.
  2. Turn off the device: Power off your Samsung phone and plug in the charging pin. Your device will start charging.
  3. Force stop Android System: Open device Settings and type ‘Android System‘ in the search box. Tap on Android System to open the app info page and then tap on the Force stop option. Now, try charging the device.
  4. Disable Fast Charging: Disabling fast charging can make the moisture-detected warning on your Samsung Galaxy device go away. The steps to reach the setting differs depending on the software version.
    • Go to Settings> Device maintenance > Battery > 3-Dot icon > Advanced settings > Fast charging and turn it off.
  5. Go to Settings> Device care > Battery > Charging and disable Fast charging
from here
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kolleso さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 15
今までの合計 67
