メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Why my phone will not switch automatically to cellular data?
I have the a1662 5se older model I bought 7 years ago. When i leave home it will not automatically switch to cellular data. Phone service says i have to do it manually to do sending texts or getting on the internet. I think it is more of a problem lately. Or is apple making my life difficult so i will buy a new phone. It also will not let me change the pin on my screen time part of the phone. So I can’t rest the network settings. Any ideas ? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Why do you have to switch? Isn’t it always on?
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
To get the cellular data to work i have to turn it off manually. It is Not switching on it’s own. So since i will not always remember to turn if offit will cause me to us up my data. So I figure apple is causing this on purpose.i have called themand they offer no explanation. As usual. If that is the case…i will not buy another iphone. But learning a new system is going to be difficult and prices are higher than they should be. So i am reluctant to anything till i find out more about this.
さんによる
Your issue sounds like a software problem. Try resetting network settings via settings>general>reset>reset network settings. If that doesn't work, try restoring the device with iTunes or installing the latest update.
On a side note, you may want to upgrade devices as that phone is pretty much obsolete.
さんによる
Yes, obsolete but it works for the little in need it. Also , I can’t reset the network since the screen time app is not accepting the code or allowing it to be set. I believe this phone has memory issues. Once it had to download the os since it wouldn’t recognize the phones code to open it. It’s just had to pay the money for something that doesn’t wash dishes or transport me to another universe.
さんによる
It also has the most current update.
さんによる
@Perry Green Why did you have to turn it off? When the phone is properly connected to wifi, cellular data will not be used.
It is too complex to troubleshoot jailbroken phone software issue, just revert it to almost clean stage.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Perry Green さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 81
