メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2626回答 すべてを表示
Samsung UE55ES6300 double, discoloured image
I have this 55” Samsung tv and randomly started having this issue. I have tried replacing the t-con board but didn’t work. Also if I check the ribbon cables and check which side of the panels the issue may come from it is on both sides of the panel.
I have the tv open so can get more images. Can anyone help?
These are the the pcb boards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@bananabread04 errors like those are commonly caused by either the main board or the LCD panel itself. Since the schematics for the panel are not available, I suggest you try a new main board. Check the LCD driver boards (boards connected to the panel by very thine ribbon cables) see if you can find any obvious damaged parts
このアンサーは役に立ちましたか?
スコア 2
15 件のコメント:
The lcd driver boards all look fine, no obvious damage. Is the main board the one which has the power cable plugged into it or where all the input devices are?
Would a picture of pcbs help you as well?
さんによる
@bananabread04 Pictures will always be helpful. The main board is the one with all the input connections.
さんによる
I have added edit of all the pcb boards, what could be wrong on the main board
さんによる
@bananabread04 the most common cause would be the video processor and circuitry
さんによる
@oldturkey03 so I left the screen last night and have just turned it on. The backlight is on but the image is gone, I’m getting no image at all.
さんによる
10件以上のコメントを表示
コメントを追加
回答を追加する
Samir さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 10
今までの合計 142
