メインコンテンツにスキップ
廉価版で携帯バージョン、統合されたJoy-Conコントローラと若干縮小したスクリーンを持つNintendo Switchハードウェアです。2019年9月20日発売。
Not switching on after fall
My son's Switch Lite fell off his bed and now it won't switch on. There's no apparent physical damage and I can't see any obvious loose connections. It has plenty of battery.
Anyone got any suggestions for what it may be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
does it make any sounds when the buttons are pressed if it does it could be the screen, other than that there are various reasons that could cause it like cpu being damaged, but its nothing anyone can diagnose online
このアンサーは役に立ちましたか?
スコア 3
9 件のコメント:
Thanks for replying.
No, no sounds. Fully dead. That is why I thought a loose connection.
Sounds like it could be just about anything, then. I was hoping that there may be a couple of likely candidates for the Switch Lites. I think I'll try a full tear-down and see if anything helps.
さんによる
@davidartley do you have a multimeter ?
さんによる
@davidartley in beep mode check the capacitors around the m92 chip to check for shorts, put the red probe on a ground like on top of the charge port and check the caps with the black probe, if any beep on both sides let me know
さんによる
Excellent, thanks. I will try this at the weekend.
さんによる
4件以上のコメントを表示
コメントを追加
@tech_ni i found four shorts on two separate points.
i have in ingress 0.14A at 5V
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I don't think they're shorts. I'm sure there should be continuity through those components.
さんによる
since you only get 5v then its more than likely m92 thats the issue as it controls the 15v. remove it and check again
さんによる
@nige56 there is only meant to be continuity through the coil not shorted, as the caps above m92 are marked red aswell
さんによる
コメントを追加
回答を追加する
David Artley さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 243
