No audio from speaker nor the handsfree
How to fix my laptop its speaker is not working (no audio) there's no audio even with the handsfree. How can I fix this issue?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
you can first start y going into settings to check the audio settings because for some reason the audio can say disabled which makes it not play. you can also connect a bluetooth speaker ot the laptop if you have one to temporarily fix the problem.
if it is a software problem follow this guide (Microsoft Audio Guide for windows 10/11)
if it is not a software error you may need to replace the speaker.
Hope this helped.
このアンサーは役に立ちましたか?
Thank You I solved the problem, it was related to audio drivers.
glad i was able to help
@gabesech I appreciate your time thank you
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 77
