I cant get any spark , I replaced my cap n rotor notsure if its my co
No spark at all i replaced the cap n rotor im not sure if its the coil or the ignition module?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I know it's a different make/model than my own vehicle, but when I couldn't get any spark it was the icm for me. Located inside the distributor. I posted a pic of yours so you can see where it should be.
このアンサーは役に立ちましたか?
I think there are several common-ish causes for this symptom. Without additional details of what all has been tried,. here are a few thoughts and some supporting links:
-bad key code
-Bad ignition coil(s)
-bad plug(s)
-damaged cam position sensor
-broken timing belt
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 42
1件のコメント
mattcannon48 what engine size does your Accord have?
oldturkey03 さんによる
