Hi
It is usually 1 of 2 things
1)a dirty charge port:have a look under a strong light for any dirt and debris,if any are found try and carefully remove it with something thin like a sewing needle or some fine tipped tweasers,just anything thin
After that carefully clean it with a toothbrush and some isopropyl alcohol
Or
2)it could be a bad battery,this is quite common due to the iPods age as battery’s degrade with age and these battery’s will be around 20 years old so it’s not rare to see battery isssues
Here’s a battery replacement guide
iPod Miniのバッテリーの交換
If the above doesn’t work you could be looking at a logicboard issue which could be solved however the microsoldering side of things isn’t the easiest for everyone so if you want to try it make sure you are comfortable with it
Hopefully this helps
Any questions please ask
1件のコメント
It turns out that all I had to do was to plug my iPod into my windows PC and the plug it out without ejecting. If anyone knows why this is, please let me know.
Simon Hansen さんによる
