メインコンテンツにスキップ
Repair guides and support for your Toshiba TV.
193回答 すべてを表示
Horizontal lines on certain colors on TV
I have a Toshiba 50UL2063DG Android TV, and it was working fine until lines started appearing on the TV, these were basically unnoticeable at first, but a while later, they started getting worse to the point where the lines would start flashing. This covers a large part of the display. Right after turning on, the TV is fine with just a few lines, but after just a few minutes, the lines cover most of the screen and flash. I have done some research and suspect a T-Con board problem, but I'm not sure.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
6 件のコメント:
Electric Shock, it won‘t be the T-con board. Horizontal lines are never caused by the t-con board. They are usually caused by a bad panel LCD driver board and sometimes by a bad main board ( not thin lines like on yours). Let‘s see if we can find out more about your specific TV. Start by checking the ribbon cables for tears and corrosion.
さんによる
@oldturkey03 Thanks for the quick reply. I have actually been struggling to find much about this specific TV, but anyways I have checked every ribbon cable, between the main board and the T-Con, between the T-Con and the LCD drivers, and between the drivers and the LCD. There are no tears, no corrosion and no damage at all.
さんによる
@ElectricShock can you post some good pictures of your boards and the interconnect cables, with your QUESTION?
さんによる
@oldturkey03 I have added some pictures of the boards and cables, if they aren't high enough quality, I can use a better camera.
さんによる
My Toshiba tv model 50UL2063DB has the same flashing horizontal lines issues after less than two years’ usage. Before then it was working perfectly fine.
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
@ElectricShock the boards look good and I checked them against some other ones and does not look, like any burned or missing components. The only boards I have nothing on are the LED driver boards. At this time, the only thing I would try is to replace the main board and see if that makes a difference. Get an inexpensive used one to try it out.
The Vestel board is really not the highest quality and all the boards have been used on JVC TV's and other less expensive models. So, anything is possible. For more info on that board, check this Vestel 17mb170
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Ok thanks, I will consider ordering the board. I have taken the old one off and it looks perfect, no burn marks or anything. I'm assuming the GPU or CPU has gotten damaged somehow. Thank you for the answer.
Edit: I have found this board on ebay: https://www.ebay.fr/itm/115313402056
Would you say that's the right one?
さんによる
Hi OldTurkey03,
I ordered and replaced the main board to the same result, the lines don't reach the end of the screen but still flash.
Is there anything else to be tried or would you call this TV dead?
Thanks
さんによる
@ElectricShock How adventurous are you? There might be a way of cutting the tabs from the LCD driver board. Let me find out if this will work for that particular panel. Anything after that is really past the abilities of what we can do/offer here since it would/could involve replacing the LCD boards and rebonding the TAB connectors etc.
さんによる
Hi OldTurkey03,
IFixit never notified me that you answered, so sorry for the very late reply. I'm pretty adventurous seen as the TV is basically dead to me at this point. I could cut the tabs from the LCD driver, but I think it might be difficult to rebond them, wouldn't it?
さんによる
コメントを追加
回答を追加する
ElectricShock さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 31
過去 30 日: 232
今までの合計 2,585
